LS1/6 swap into 95z28
Im thinking of doing a LS1 or 6 swap into my 95 z28. All i would like to know is what would i need to do it, and how much would it cost? Aside of the motor, i know its going to be a few grand. Any help would be nice.
Thanks in advance.
Thanks in advance.
k-member, can be found used for 50, or 400 or so for a tubular
motor mounts - 150 for spohn solids
if you are using a lt1 4l60e you would also need the flexplate spacer which is around 50 IIRC
The wiring harness you can get with the motor, along w/ the computer, etc.
Its really a pretty straight forward swap IMO.
yes, you just need a flywheel spacer. Part from hughes is HUP-HP3750 if i remember correctly. I have one laying in the garage I can double check wednesday or thursday
gonzo275rltw
3rd Gen / L98 Engine Tech
09-07-2015 04:46 PM
gonzo275rltw
09-05-2015 06:26 PM
gonzo275rltw
09-05-2015 06:24 PM
