LS1 brakes larger than LT1s??
Old 11-03-2002 | 07:54 PM
LS1C5's Avatar
I've got a '99 SS and I bought some steel rims with snow tires off a guy that had a '94 Firebird. They are 225/50 16.
When I went to install them today, it seems to be rubbing the brake caliper.
Can somebody confirm that the LS1 brakes are larger than the LT1s??
Thanks!
Old 11-03-2002 | 08:14 PM
Z-Attitude's Avatar
Yep
Yes they are slightly bigger on the new models. I did not know the wheels would not interchange though . The manual says that 235/55/16 or 245/50/16 for tires on them. The rim you have sounds too narrow. Later>>>>>>>
Old 11-03-2002 | 08:30 PM
chuck's Avatar
Yes LS1 brakes are larger than LT1 brakes. I think the LT1 rotors are 10" and the LS1 rotor is 11.8".
The problem isn't the tire, but the wheel. SLP sells take off 16x8 Firebird wheels for $50 each.
Old 11-03-2002 | 11:45 PM
LS1C5's Avatar
Thanks for the help guys. I guess this means that if I go with a wider rim I'll have to spring for new tires too?!?
Old 11-03-2002 | 11:58 PM
Jerm93z28's Avatar
just get a set of salad shooters or '97-99 5 stars. those are pretty dang cheap now, especially the salad shooters! '93-96 salad shooters might need a tiny bit of grinding on the part that goes over the hub protrusion.
jeremy
Old 11-04-2002 | 01:03 AM
racehead's Avatar
yeag they're bigger, still not quite big enough however ....
Old 11-04-2002 | 04:49 PM
Ken S's Avatar
that and the pads are bigger, and the caliper are a two piston side by side design now.
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
ddr698
01-09-2015 10:05 AM
vals95z
03-18-2003 03:45 PM
Quick Reply: LS1 brakes larger than LT1s??
