ls1 cam with same stats as cc306?
i know nothing about lift, duration etc.
Just wondering if they have a cam for the ls1 like the cc306.
also the engine is a 01 ls1. Will i loose power anywhere if i replaced it with whatever has same stats as 306?
sorry for the dumb questions but thanks for the help.
why do you want those stats, the ls1 is totaly different when comparing to the lt1. You won't loose power but it might hurt your low end. Most guys who put a big cam in have to rev to 6800 and gear the hell out of it. Personaly i would look into a proven cam that you can find cheap. somthing like the thunder 224 cam.
10-31-2016 11:09 AM
ZBLKHELLRZR
08-18-2002 07:57 AM
