LS1 to LS7 or LS6?
Old 01-29-2006 | 03:01 PM
  #16
Dyosis's Avatar
Re: LS1 to LS7 or LS6?
From what I have gathered over the past few months of reading posts. I thought the LS1 and LS6 were the same block and internals with just different heads/cam/intake.
Old 01-30-2006 | 06:22 AM
  #17
JakeRobb's Avatar
Super Moderator
Almost. The LS6 block has some extra windows for better breathing. You can read about the difference here. The LS6 block does not, in and of itself, make any more horsepower than the LS6 block. In fact, most engine builders prefer the LS1 block for strength in extremely high horsepower applications.
Some 2002 LS1 cars were built using LS6 blocks. I haven't had a chance to see if I lucked out yet.
Old 01-30-2006 | 01:40 PM
  #18
Aaron91RS's Avatar
lol according to scott's posting right here all 01's and 02's have the same block.
Old 01-30-2006 | 06:41 PM
  #19
JakeRobb's Avatar
Super Moderator
I don't know which one is Scott, but either Scott is wrong, or you interpreted him wrong.
Switching out one for the other will not get you more or less power -- maybe that's what you read. The castings are slightly different, though.
Old 01-31-2006 | 09:57 AM
  #20
Aaron91RS's Avatar
Scott S works at GM. I think I'll believe him over you when he calls it a legend
Old 01-31-2006 | 12:06 PM
  #21
JakeRobb's Avatar
Super Moderator
Ohhh, that Scott.
Well, I can pretty much guarantee you that Scott didn't say that the LS1 and LS6 blocks were identical, because they're not. There are pics on ls1tech.com -- I linked to them a couple posts back.
Old 01-31-2006 | 12:39 PM
  #22
Aaron91RS's Avatar
No he said all 01-02 f-bodies have the same block
There's the old "Mine has an LS6 block" legend........well....in 2001 and 2002, they all have the same block. THe difference is that the 'bright silver' blocks were cast at Ste. Catharines, ONT and the darker blocks were cast in Mexico.
Old 01-31-2006 | 01:03 PM
  #23
Klypto's Avatar
some 01-02 fbodies have the ls6 block... know that for a fact, was a small percentage, but they are out there...
cory
Old 01-31-2006 | 01:33 PM
  #24
JakeRobb's Avatar
Super Moderator
He misspoke, or was misinformed. A small fraction of '02's got true LS6 block castings, verifiable by the casting number, or if you really want to be sure, you can tear the engine down and see the additional windows in the block for yourself.
Since the casting number itself is part of the cast, there is no way that an LS1 casting would get an LS6 part number on it.
Old 01-31-2006 | 01:50 PM
  #25
Capn Pete's Avatar
Agreed, there were SOME LS1s in '02 (and I thought a few in '01 as well? ) that came with the TRUE "LS6" block. Very small number, but not a "myth" or "legend".
As far as the question about putting LS7 heads onto an LS1, I don't think it's physically possible because of the size of the valves, and the fact that they would contact the top of the cylinder bore (which is 4.125" compared to only 3.89" of the LS1). However, a re-sleeved LS1 block should be able to accept them .
13qtr
10-28-2016 08:11 PM
Ericksd
01-20-2016 06:07 PM
JJOHNROE
Parts Wanted
10-23-2015 02:03 PM
Hal Fisher
09-30-2015 09:03 PM
Z Power
09-19-2015 11:19 PM
Quick Reply: LS1 to LS7 or LS6?
