ls1 trying to die
Old 12-21-2003 | 06:13 PM
FLIPPINZ28's Avatar
ls1 trying to die
i bought an ls1 camaro a while back it has a few mods lt headers fastchips ported maf. cold air induction. and the car after cruising for awile it tryies to die but i rev it up and it works fine. and occansionally when it does it i rev it up and it will smoke grayish black smoke that is what my sisters husband said the color of it was. my question is will the fuel pressure be causing this i bought the car with a adjustable feul regulator i was told it is sat at 61 pounds of pressure. could this be the cause of it doing this thanks abunch alos i have a gauge on the way to be sure where it is sat at.
Old 12-21-2003 | 08:27 PM
SFB767's Avatar
Maybe you need to replace the fuel filter.
Old 12-21-2003 | 08:59 PM
Antz97ZNJ's Avatar
Yea im thinking its not getting enough fuel, bring it to GM and get it scanned
Old 12-21-2003 | 10:00 PM
Strahley's Avatar
Do you have an aftermarket cam? Mine has the LS1 Hotcam, and has not been tuned yet. It does exactly what yours does, with the added fact that I usually have to keep it alive for a bit when I turn it back on after it's been off for just a little bit. A nice dyno tune will cure mine though, and it may also cure yours
Old 12-21-2003 | 10:11 PM
FLIPPINZ28's Avatar
I know its not the fuel filter i am getting more than enough fuel it runs rich cause of the black smoke. The pressure was sat at 65 now down to 51. it runs alot better now. what would yall suggest on the fuel pressure thanks
Old 12-22-2003 | 04:18 PM
chpmnsws6's Avatar
i think 51psi is right for an ls1
Old 12-22-2003 | 10:55 PM
FLIPPINZ28's Avatar
okay drove alot today problem is still there i replaced the idle air temp sensor i beleive that was what i replaced still no good. maybe mass air please help
Old 12-23-2003 | 08:22 PM
Fear The Z's Avatar
You know that "guessing" gets expensive. But since your guessing- I would have to say change the plugs out. From what I understand, you was running way too rich- seems like it would foul out the plugs.
Old 12-23-2003 | 09:03 PM
FLIPPINZ28's Avatar
thinks fear the z that totally slipped my mind. see i have a 94 camaro with an 01 ls1 engine so some of my gauges dont work and my service light is always on cause of the wiring so i ahve to guess right now so i think i will try the plugs
Old 12-23-2003 | 10:37 PM
Fear The Z's Avatar
Find someone with a tech 2 they can hook up to your car and see whats acting crazy. Hope you find out whats wrong.
Old 12-24-2003 | 10:56 PM
FLIPPINZ28's Avatar
thanks
1slow93z28
09-01-2015 06:22 PM
Nickster 7
08-27-2015 10:12 PM
Jocofire1
08-07-2015 03:16 PM
Dark Zeiro
07-19-2015 08:25 AM
Quick Reply: ls1 trying to die
