ls2 in typhoon NEED HELP
Old 01-30-2007 | 01:44 AM
zoo choo's Avatar
I have a 1993 gmc typhoon and I am going to try to fit and wire a ls2 in there.does anyone have any knowledge of this will work,if I need to make any custom brackets so on and so forth.please help.thanks,
Old 01-30-2007 | 03:10 PM
LT1Formulation's Avatar
Ask some people who have done LSX swaps into S10's. There shouldn't be much difference. Congrats on picking an awesome ride to do the swap with. I'd put a turbo on the LS2 as well
Old 01-30-2007 | 08:26 PM
Greed4Speed's Avatar
How and are you going to keep the AWD?
Old 01-31-2007 | 01:45 PM
91RSLT1's Avatar
My question is WHY? I would keep the 4.3 turbo motor. The time and money is not worth it, use it to mod the 4.3 turbo. Bottom line if it is a real Typhoon DO NOT DO IT, not worth it.
Old 01-31-2007 | 01:58 PM
zoo choo's Avatar
the 4.3 does not have the power of a ls2 and to get that power will cost a ton of money.plus I plan I driving this truck all the time and I don't want problems with a turbo motor when it is 104 degress outside.
Old 01-31-2007 | 02:02 PM
JakeRobb's Avatar
Super Moderator
If you insist on going this route, sell your Typhoon, buy a Jimmy, and put the LS2 in there. Real Typhoons are rare enough as it is -- don't wreck it!
Old 01-31-2007 | 02:45 PM
gota406's Avatar
LS2 wiring
Good luck with the swap. I'm sure you'll have a one of a kind with great value to you when done. Check over on thirdgen.org for your wiring questions. There is a guy doing one right now. Also, the brackets may need fabbed due to the placement of the LS based engines is a little off with the design of the bellhousing.
Old 02-01-2007 | 10:29 AM
The 4.3L may not have the power of an LS2, but being able to keep the AWD more than makes up for it when racing.
You shouldn't have any problems building a 4.3L thats just as quick as the same RWD LS2 combo for less $ than the swap and with the same reliability. GN guys do it in an overweight RWD car with less cubes....
A friend's brother had a nicely modded Sy that was a terror and it was daily driven.
Hotrods&Muscle
01-28-2015 09:35 PM
Hotrods&Muscle
01-24-2015 09:57 PM
Hotrods&Muscle
12-21-2014 03:57 PM
elec87
02-21-2004 03:58 PM
whoa guy
Track Kill Stories
11-16-2003 12:12 AM
Quick Reply: ls2 in typhoon NEED HELP
