LS6 on 2000,
Old 10-31-2002 | 05:45 PM
Quiksilver's Avatar
LS6 on 2000,
Im gonna replace the stock intake to get rid of the egr system, it wont seal goin into the intake and throws codes and i have o jiggle it to idle right occasionally, ive tried a few different things and decided to go with a different intake sooner than expected. My question is what will the computer do when you remove the egr system and increase air flow? Will i have no problems OR will i have to take it to someone that can change my computer like ls1edit at dynoshops? And is holleys ported aluminum intake any better? Nick
Old 11-01-2002 | 01:08 PM
robz71&00sS's Avatar
ttt
Old 11-02-2002 | 10:16 PM
pekkaz's Avatar
You will get codes from deleting the EGR and will need to do some ls1_editing to get rid of it. There are lots of horror stories out there on the Holley intake.
Old 11-03-2002 | 11:38 AM
mdw9965's Avatar
The SLP LS6 intake has an EGR provision with a threaded interface and compression fitting that would probably eliminate the problem you are describing. The EGR oring seal can be finiky especially if you did the EGR tube mod.
Old 11-03-2002 | 06:07 PM
SUPERSPORTBOY2's Avatar
ttt
JJOHNROE
Parts Wanted
10-23-2015 02:03 PM
Z28ELECTRICIAN
10-19-2015 06:36 AM
68camaroboltz
10-05-2015 11:56 PM
pepon214tx
09-20-2015 04:48 PM
scottcba1
09-08-2015 09:52 AM
Quick Reply: LS6 on 2000,
