LS7 Engines
It is entirely possible, and actually, in the new issue of GM High Tech Performance, they talk about how GM Performance Parts shoehorned an LS7 into a camaro of theirs. Not sure of the year.... but if I remember correctly it was a '00. As for what you would need, it's a pretty extensive list, and would definitely cost a pretty penny. If you can find it, I would pick up that issue of GMHTP, it will help you learn quite a bit.
Hope I was of a little help.
Edit: Here's a link to the article I am talking about.
GMHTP LS7 into '99 Camaro
If you want it for bragging rights to say you have an LS7, maybe it is what you want. But for the money, you could spend it on other built engines and end up with comparable power if not more. I am sure there would be more than 1 support vendor who would help quote you a price.
But to make it work... alot of $$$$
Well money is not a problem and the reason i want it is because a have an LS7 and a 2002 Camaro and i want to put it in there, and the only reason is becuase the LS7 is GMs most powerful stock small block and also i am going to have a custom twin supercharger set up but i was just wondering if the LS7 could actually fit in the egine bay and wouldnt need any exterior body modifications like widen the egine bay or the body
People need to understand ALL gen III/IV blocks are the same exterior dimentions. From the 327 cube 4.8 to the 427 cube LS7 the difference in cubic inches is internal.
The hitch with the LS7 is the dry sump oil system pan and hoses will require you to go with a tubular Kmember.
And as far as the hp ratings of the LS7 yes it's the highest hp STOCK gm motor but you can easily build an LS2 to that hp level for way less money. Heck my little 346 heads/cam combo puts out near those numbers.
This topic gets talked about it seems like on a weekly basis on LS1 tech. It seems to me. you can build a really mean LS1 ie. head cam turbo if you wish. and come out with the same number for less than its going to cost to get your hands on an LS7 and get it in the car.
Man, I want a damn LS7. nice lopey cam installed with all the supporting mods. I would probably pass out every time I started it. I am thinking LS7 in my future. Not sure what tranny to put it with though.
Though the flat black paint and black Z06 rims try to keep this puppy low-key, the exterior, replete with SS hood and rear spoiler and enhanced by the ballsy GMPP TEST VEHICLE graphics on the doors and rear LS7 badge, is about as understated as a kick to the jimmy.
