LT1 man with a LS1 question (Teflon Piston #1 Cylnder)???
Old 08-23-2003 | 10:51 AM
OBDIICamaro's Avatar
Ok I picked up a warranty engine from a GM Mechanic and it runs fine and all but it was warrantied because it has a "Ping" in the first cylnder. He says that this is common so GM had to design a special Teflon Piston, is this true?
Old 08-23-2003 | 04:43 PM
DJD's Avatar
DJD
Unhappy
I think all the pistons are teflon coated, to get away from piston slap, but it is not working. mine is a 2002 with 7400 Km. on it and it has piston slap. Check out this web site www.pistonslap.com Chevy. Like a knock!
Old 08-23-2003 | 05:46 PM
Its a 2002 Engine from a Vette with 1500 miles and I picked it up for $500 minus intake and throttle body.
What is the cure for this, if I decided to go with a stock size forge piston and new rings would that help?
Old 08-24-2003 | 03:13 PM
pg318's Avatar
'02s have the coated pistons. The coating is intended to prevent the piston skirt picking up on the bore during cold start, since the new pistons run a tighter clearance to try to reduce the noise. The TSB for fixing the ping was as far as I've heard, to measure the pistons, and put the largest one in bores 1 and 8, which tend to be larger. I'd guess that the only positive fix would be a hone or rebore and new pistons.
The real issue is that the LS engines run short skirts, which make them more sensitive to tolerance variations.
1963SS
02-06-2015 10:05 AM
Hotrods&Muscle
01-28-2015 09:35 PM
jayblev95
Track Kill Stories
01-15-2015 07:48 AM
Hotrods&Muscle
12-21-2014 03:57 PM
ChrisFrez
11-23-2014 10:33 AM
Quick Reply: LT1 man with a LS1 question (Teflon Piston #1 Cylnder)???
