metallic grinding noise 99 Z28
99 camaro Z28 5.7 liter V8/Auto/12,000 original miles.Theres a metallic grinding noise coming from the left side of the engine. The metallic grinding sound stops when I either put on the A/C or defogger. So to recap I hear metallic grinding noise...and when I put the A/C or defogger on I then hear the clutch engage and the metallic grinding sound goes away. It immediately comes back on when I shut the A/c or defogger off. I noticed the belt tensioner on the top left of the engine shakes. I put more tension then less tension and the noise is still there. I dont believe its the belt but its possible.Maybe a pulley is loose or needs replacement. Maybe its the tensioner pulley. I dont have any idea. Any advice? Thank you so much in advance. Please reply to cobrakillr718@yahoo.com
Re: metallic grinding noise 99 Z28
And please do not post questions on this board and expect us to e-mail you the answers. If you can post the question here you can come back and read the answers here. thanks.
thanks for replying. If it is the clutch bearings is this an easy fix? Would I just need to replace the bearings or get a new clutch or compressor? and did you have similar problems? Thanks
Deadbolt24
01-19-2015 01:29 PM
squarehead
11-21-2014 08:02 PM
