Mobil 1 oil questions
Old 09-26-2002 | 09:09 AM
psychocabbage's Avatar
I changed my oil this weekend and the car feels smoother if that is believable.
Is this normal?
The other question I have is where can I find a Mobil 1 oil filter!?!
Old 09-26-2002 | 10:38 AM
ZZed's Avatar
Never heard of a Mobil 1 filter. I just use a Fram and Mobil 1 full synthetic. All is good. How many miles do you have?
Old 09-26-2002 | 10:43 AM
Zdriven's Avatar
Thumbs up
I got my Mobil 1 filter at Autozone. I don't know if there
are any of this franchise in Texas.
IMHO, Fram should NOT be used. Fram uses a cardboard
endcap inside the filter, not metal like some other filters.
Then again changed often enough most oil filters will
hold up.
Old 09-26-2002 | 12:17 PM
1sloLS1's Avatar
the reason i dont use a fram is cause i have heard of some cases where you might have something wrong with your engine and the dealer will not warranty the prob if you have a fram filter due to the fact that they do not let the oil flow as free.
Old 09-26-2002 | 12:28 PM
Patman advised me to use the Purolator filter if I cant find the Mobil1 M1-206. So I am looking for that filter now..
I have the purolator but it was such a pain to get everything that I want it all ahead of time now.
I have just over 4300 miles. Did my 1st oil change at 4225.
Old 09-26-2002 | 02:19 PM
birdblack's Avatar
I changed my oil last wkend using Mobil 1 and a Bosch filter. 3332. I had 2 observations. One, the Bosch had a larger diameter then stock Delco. It fit with room to spare but I was concerned when I got the Delco off and compared sizes. The other observation I had was my oil pressure seems to be higher with the Mobil 1. I bot the car ('01 Formula) a couple of months ago. The dealer had changed the oil prior to me buying it but with regular Mobil. I only have a few miles on since the change so maybe it's only a matter of new oil. Or maybe it's the new Mobil 1 filler cap I put on.
Old 09-26-2002 | 04:18 PM
ZZed's Avatar
Yikes!!! I'll have to re-evaluate my filter choice. I cahng my oil every 3-4000 miles. No oil consumption problem to date. 40,000 miles. I'll have to research that filter. That AC filter (PF44) is always out of stock. I'll look into a Mobil 1 filter. Thanks.
Old 09-26-2002 | 05:31 PM
Nate00SS's Avatar
Smile
I felt the same thing the first time I changed with Mobil 1. I may have been imagining things, but I swear that it was an immediate improvement - it felt like it was running smoother. I picked up my Mobil1 filter at AutoZone also - I haven't seen them too many places around though.
Nate
Old 09-26-2002 | 07:51 PM
z28chrizz's Avatar
I too use the mobil 1 filter. 12.99 at autozone. Add that to the 17.99 5qt containers of Mobil One 5W 30 at Wal-Mary and it isnt too painful to do an oil change. (I have only put 18k on my car in over 2 years)
I also noticed that the engine seemed a teeny bit smoother when I switched, but I also noticed more noise from the valvetrain which doesnt make sense. I run at about 45-50 psi at idle (warm) and it will swing north of 60 if I rev it hard. No oil consumption, inspite of weekly autocrosses and the occasional trip to the drag strip.
On a side note.... I also switched to Mobil One gear oil in the rear axle and i now get a "howling" of the gears at about 50 mph when i am off the gas. I assume this is imperfect meshing of the teeth on the gears. Can anyone confirm or refute this? (Yes I used the GM rear additive for the limited slip)
Somehthing I should be concerned about? Its been like this for 10k + so its probably too late if it is...
Old 09-27-2002 | 09:33 AM
ZZed's Avatar
What is the part number for a Mobil 1 filter?
Old 09-27-2002 | 09:42 AM
M1-206 is the number you want as it is a little bit longer I am told.
Old 09-27-2002 | 10:56 AM
mmannSS's Avatar
Not sure about the warranty issue but I quit using fram when i got my truck and heard about the poor quality of frams. Do a search on yahoo for oil fitler tests and you should find the article. Basically an exploration into the construction. It found that the fram was bad build quality/materials. The delco and purolator both did well. I personally use the delco on both the truck and ss
Old 09-27-2002 | 01:41 PM
z28chrizz's Avatar
The OEM replacement size is M1-107
HectorM52
07-30-2017 11:46 AM
93440supernat
01-12-2015 06:35 PM
Joes96z
12-13-2014 07:48 PM
94B&RZ-28
12-22-2008 10:00 AM
07-04-2005 05:00 PM
Quick Reply: Mobil 1 oil questions
