MS3 vs. FM 15
MS3 vs. FM 15
i'm fixing to upgrade and buy an ls1 powered camaro. i was wanting to put in a cam as one of the first major upgrade. i have a choice of going with the MS3 237/242 .603/.609 112 LSA 2300-6800 RPMs. see i like this cam but someone has it here in my small town already. i wanted something around the same but that might pull out in front of it without being way bigger in specs. i was looking at the FM F15. it's a 236/239 .600/.611 111 LSA. 3500-7200 RPM's. see the car i'm looking at is a six speed. his is an auto with heads i think a with a higher stall. let me know what you guys think.
if he has the MS...and heads...you're gonna have to have one STRONG running car to match it. even though his will eat alot of power with the auto and stall...it will be a wicked car.
either cam should work fine. just make sure you have the supporting mods to back it up...especially clutch and tires
I had great results with the Futral F15 cam, however, the cam isn't for everyone. It's got ALOT of lope with not much low-end below 4000 rpm, but where it really shines is around 4400+. You're going to have to launch your car hard with any cam that size, so getting a 12-bolt is a no-brainer if you're doing any kind of drag racing with a 6-speed car. It's a nice cam that makes high-rpm power and should make 420+ rwhp with all supporting mods and a good dyno tune.
Here's a couple old vids:
http://kraest.com/vette/idle.mov
http://kraest.com/vette/2ndgear.mov
http://kraest.com/vette/3rdgear.mov
As just stated, your going to need a good setup. It's going to have to have it all if you want to keep with the that other car. Another problem with keeping up with his car is going to be your launch. So after you get the motor squared away get the suspension dialed in. good luck
NewsBot
07-03-2015 02:10 PM
NewsBot
01-29-2015 07:10 PM
NewsBot
01-11-2015 06:10 PM
NewsBot
12-28-2014 06:20 PM
