Mufflex 4" vs. "True" Duals...
From: from the land of Justin Wilson and Huey Long!
Mufflex 4"...better choice. Sounds awesome, especially with aftermarket cam and Hooker LT's...Potentially more flow than "true" duals...Potentially
Thanks! I have heard a Mufflex 4" on an LT1 and I loved it... Are you all using the spintech or the flowmaster or something else?
I just am thinking of the two as options because:
1. If I am going to pay alot for an exhaust I want something not everyone can get or has..
2. I want to see definate gains.
Thanks for the formula.. I was thinking about doing the dual electric cutouts at the end of some longtubes.. what kind of negatives are associated with that if you know....
Flowmaster. I personally think it is a little restrictive, but that what was offered from Mufflex at the time the stroker was built. An electric cutout would definately be a plus. I'm trying to remember who makes the 4" custom cutout...if I remember, I'll post...
Is this a single 4" system or dual?
Unless you have done serious engine mods including increased displacement, you do not need dual 4" of piping...that is just huge. Even with heads/cam/intake/exhaust, dual 3" is perfectly adequate.
Now single on the other hand, that makes more sense. That's a huge pipe though, I'd rather go two smaller dual pipes. Just MO.
mufflex kicks ***
Installed mufflex 31/2 years ago on 96 blower car w/headers and spintech WOW still loud as hell w/nice rumble at idle and criuse.
only down on that install on severe bumps mosier 12 bolt hits pipe. one 4'' outlet.
Just installed mufflex 4'' on 2000 WS-6 M-6 twin outlet (stainless oval tips) the new stuff looks 100% better than factory and sounds great. Its realy hard to tell w/this car if improvements were made as my *** dyno is biased.
After the rest of the mods are made I will get the build sheet and dyno results posted. so far lingenfelder cnc ported heads and cam, Z-06 intake (calibrated as 2002 egr fix),Z-06 clutch and flywheel, FLP headers cat and Y pipe, mufflex 4'' Y back w/spintech, K&N F.I.P.K., spohn arm and strut tower brace, to be continued...
I considered going to a 4" exhaust , but have decided on going with a 3-1/2" exhaust. Should be a big upgrade vs my basically stock exhaust with a Flowmaster muff.
I just think that a 4" exhaust is to big unless you have a very radical combo. Bigger is not always better.
I am pretty sure that Baxter runs a 4" exhaust and he probably making in the area of 900+ rwhp. He runs 9.0's@155+.
I have also never seen any dyno's of anyone comparing a stock or 3" exhaust vs a 4" exhaust.
I think that cross sectional area is only part of the equation here. Also the friction between exhaust gas and the walls of the pipes must be considered. I think true duals have more surface area for the exhaust to contact therefore more friction even if the total cross sections of the duals added up to be equal to the single. This might have nothing to do with your point (if so sorry) but am I right?
Mufflex
I currently run the Mufflex 4" catback with the Spintech muffler and dual tailpipes. Really like the sound that it puts out. Very unique. I had in mind at the time a single turbo and am now leaning on the side of a H/C/N2O 382. If I do go that route, I really would like to do true duals, as its something different in itself and Im sure it would sound bad *** on an LS1. I would most likely go with the dual 3"s X pipe and bullets.
Phat T/A, you have any sound clips?
VVVV Sound clip of Mufflex w/o cats in sig. VVVV
NewsBot
07-03-2015 02:10 PM
NewsBot
01-29-2015 07:10 PM
