Nasty noise from rear suspension
Old 01-27-2005 | 12:52 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
don't really know how to describe it except for a very defined, extremely bothersome creeking/squeeking coming from the back suspension whenever the weight of the car shifts... on acceleration, the little jump after you come to a complete stop... cracks in the road etc....
checked the rear hatch... definatly not the problem.
common thing? easy solution?
please say yes to both
bad enough where i need to keep the stereo on to keep from getting angry
thanks
Jared
Old 01-27-2005 | 08:04 PM
stock98z's Avatar
Re: Nasty noise from rear suspension
Check to be sure it's not your spare tire mount or tool. Mine was doing that and nearly drove me crazy before I could find the problem.
Old 01-27-2005 | 08:06 PM
MasterEvilAce's Avatar
Why would you not keep the stereo on?
Old 01-27-2005 | 08:46 PM
frmula1's Avatar
checked the tire and tool.... very tight and secure... not the problem
*because i occasionally like to hear the exhaust
its definatly (sp?) a spring-like creeking/squeeking almost sounds like someone moven around above you in an old wore-out spring bunkbed.
and i can make it do it, audible from outside the car just by quick pushing up and down on the bumper..
can i spray lube on the connections or something? would that help at all... it didn't do it at all first 2 days i had it... then all of a sudden its doing it ALL the time
Old 01-27-2005 | 10:58 PM
PJS TOY's Avatar
You probably just need to lube those two bushings under your axle. They are the ones that the rear sway bar passes through. Worked for me. Use a good synthetic grease. Regular grease will just wash out.
PJ
Old 01-27-2005 | 11:21 PM
kringer2's Avatar
Smile Re: Nasty noise from rear suspension
mine makes that same noise. i agree check the bushings. mine squeeks at the sway bar bushing. i'm just too lazy to lube it. besides you cannot really hear it over the exhausr.
F'n1996Z28SS
08-23-2023 11:19 PM
PublicEnemy1
04-07-2015 12:21 PM
94z28jbw
09-08-2002 03:22 PM
guionM
18
07-23-2002 04:24 AM
Quick Reply: Nasty noise from rear suspension
