Need help : Just got 98 Z28 and it has rear end squeel
Old 10-27-2003 | 12:08 AM
Fishv12's Avatar
The car is almost perfect but I noticed that today. Actually I noticed only 3 things wrong with it. But the most important is the rear squeel I am hearing when cornering... It is a high pitched squeel and happens only when cornering. I have seen many pages for LT1's having problems like those and it ended up being the shims that need replacing. How much would I be looking at ? How hard is it to do ? Is there any FAQ somewhere ?
Other thing is a burned driver front signal bulb, and slightly craked windshield. I also have a small tear in the leather can this be fixed ?
Old 10-27-2003 | 12:16 AM
AL SS590 M6's Avatar
Moderator
I would do a lube change on the rear. 2 quarts of 75-90 and a bottle of Lubrizol posi additive from GM.
See if that helps.
Old 10-27-2003 | 12:40 AM
alex94z's Avatar
ditto, change out the fluid and put in some posi additive.
Old 10-27-2003 | 02:50 PM
Fishv12's Avatar
I had it done today at the dealership and it seems ok. They were not able to reproduce the noise but it seems smoother now. I've got a recal on the egr valve can someone tell me what that is ?
oldschool
02-09-2016 09:21 PM
Collector Car
01-05-2015 10:58 AM
nodnarb481
Middle Atlantic
01-01-2015 11:43 PM
ModdedNerd
12-25-2014 05:51 PM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
Quick Reply: Need help : Just got 98 Z28 and it has rear end squeel
