Need a little quick LS1 info to settle an argument
From: Teeter-tottering between Brilliance and Insanity
Im a gen 1 SBC guy so I dont know much about the mechanics of the LS1.
Need 5 things real quick to settle an argument with a guy. All LS1 info LS6 aside.
Block: Cast Iron or Aluminium
Heads: Same Question.
Crank: Iron or steel
How Many bolts are the main caps.
And what exactly is the displacement?
Re: Need a little quick LS1 info to settle an argument
the block is aluminum as well as the heads. Displacement is I believe 346 cubic inches. Might be 347. I'm sure someone else will finish this up for me.
Damn, Im gonna lose on that part. I knew the heads were aluminium but I thought the block was cast.
while were at it can someone tell me the Bore x stroke?
Block & Heads: cast aluminum.
Crank: not sure, but likely cast, not forged.
Main Caps: as stated, 6 bolt...........4 from the bottom, 2 in from the sides (needed for extra rigidity because of aluminum block).
Displacement: we had a BIG debate about this awhile ago, and because of the differences between metric and standard measurements, numbers range anywhere from 346 to 347 cubic inches, but it still rounds to 5.7 litres. I believe it's truly 346.'something', but regardless, it's somewhere around there.
Bore & Stroke: (relates to above): 3.9" (or 3.89"?) bore X 3.62" (or 3.625"?) stroke. Compared to the Gen-I 350, it's like a "stroker" engine sorta! (4" bore X 3.48" stroke).
Well, hope that helps.
Well it helps....some. But i have to admit defeat against the block thing. I have bet money that it was cast....Im glad I didnt
Aside from the increased horsepower output of the LS1's, I think why they work so well in the F-bodies compared to the LT1's is probably because of the weight saved by using an aluminum block and heads instead of the cast iron parts of the LT1 (just my $.02).
Originally posted by chevy qc
you win then. it is cast. it sure isn't billet or forged aluminum.
Like he said he would have lost.
Hey, it's the 21st century, it's all how you PERCEIVE it, isn't it?
Originally posted by robvas
The LT1 had aluminum heads, but the aluminum LS1 block and 'plastic' intake are lighter than the LT1 counterparts.
I'm not sure, but i just glanced at all the posts and didn;t really see any real answers. Here's the low down. The LS1 is the mack-Daddy. It shares no parts with any other small block except for rod bearings i believe.
Block: Cast Alum
Heads: alum with countless millions in fluid dynamics research make these heads some of the best right out of the box.
Crank: Im not sure on the material, but NO ONE has ever broken a stock ls1 crank. it will handle over 900 hp out of the box.
Mains: 6 bolts like mantioned above (4 in the bottom, and 2 in the sides)
Displacement: 346 cubic inches. Bore: 3.898" Stroke: 3.622"
Block: Cast Alum
Burmite
34
07-05-2002 12:00 AM
