Need more power..
Old 09-01-2009 | 09:43 PM
  #16
Chrome383Z's Avatar
Originally Posted by Marc 85Z28
If you've got 3.23 leave it alone.
I'd still jump up to 3.73 even if he has the 3.23. I did and it was a noticable difference. Now I agree if you have to pay to get it done, I probably wouldn't bother.... but if you can do it yourself it's < $200/parts and took me about a day to do (was my first time setting up gears). Although it did take some research, but I also had all the tools, dial indicators, and such to do it as well....
Old 09-01-2009 | 11:07 PM
  #17
Eric@Victory Racing's Avatar
you just received a pm
Old 09-02-2009 | 07:32 AM
  #18
Monosyllabic's Avatar
Originally Posted by 30th_ANNIV_Z28
the 99 Z28's came stock with 3.23 gears
No, they were optional. 2.73 gears were standard on the automatic cars.
Find out what rear gear ratio you have. If you've got 2.73s, look to upgrade to a 3.42 or 3.73. If you've got 3.23 leave it alone.
Ok..once again then, how would I find out for sure? is that something I need a mech for, or can I check just by lookin at something in the car?
Old 09-02-2009 | 08:40 AM
  #19
Marc 85Z28's Avatar
Look on your drivers door jamb for a sticker with a bunch of alphanumeric codes. These are your RPO codes, and tell you what your car was built with. GU2 means you have 2.73, GU5 means you have 3.23.
Old 09-02-2009 | 03:54 PM
  #20
30th_ANNIV_Z28's Avatar
i didnt know that. good to know.
Old 09-25-2009 | 09:43 AM
  #21
kevc14's Avatar
What about upgrading the cam shaft. they cost about $500. but how much will installation cost? How much does it usually cost to take out the engine?
Old 09-25-2009 | 10:36 AM
  #22
johnny6's Avatar
It's alot of money involved, you will need to upgrade springs, valves depending on what size cam. You'll also need a new timing chain, oil pump (recommended) and why do you need to take out the engine? Labor costs will kill you on a cam swap, do the reasearch and do it yourself.
Old 09-25-2009 | 01:30 PM
  #23
1996camarors's Avatar
So, forgive my ignorance.. Never been much of a mech when it comes to cars.. I just got a 99 z28.. v8 5.7l and wanted some advise for giving it a lil more boost.. (not that its not fast already) Whats the first step to juicin it up? Sorry if this is a cliche post..
Turbo
/thread.
Old 09-30-2009 | 11:54 AM
  #24
Chrome383Z's Avatar
On a budget it can be done for around $1,000 doing the labor yourself. I'd say $2,000 with labor but I really don't know for sure...
Old 10-17-2009 | 11:38 PM
  #25
reamo04's Avatar
Originally Posted by 1996camarors
Turbo
/thread.
yes, because a turbo on a stock motor is a GREAT idea
honestly, headers, exhaust, a lid, gears, and stall should get you by for now
Old 10-18-2009 | 01:12 AM
  #26
Cam98Z28's Avatar
A rear mount turbo at 5psi or a ProCharger at 5psi is perfectly fine on a stock motor.
aknight_sa
16
11-18-2012 12:16 PM
97superchgedz28
05-12-2012 12:12 AM
formula90
10-01-2011 10:07 AM
MusPuppis
04-04-2007 09:38 PM
kainZ
09-14-2005 11:19 AM
Quick Reply: Need more power..
