need tuner in Iowa
Re: need tuner in Iowa
Originally Posted by teke184
what kind of tuning?
mail order from madz28 or pcmforless would work fine depending on your mods
depends on your mods.
if its something fairly common they can usually dial it in pretty good.
when you consider a typical tune on a bolt on car only gets about 15hp...if they mail order is slightly off you'll probably still see 10hp. and the part throttle and around town stuff is usually improved.
simple things like changing the fan settings can keep the car cooler and make more power.
08-24-2015 06:41 AM
