new intake
http://web.camaross.com/forums/showt...threadid=94398
Simple process, I hope this takes care of your problem! Sounds like it would!
when i replaced the stock air lid with an SLP lid, i noticed that when i bliped the gas it would almost dip down to 400-500rpm.
so i drove it around the block and WOTed it a couple times.
it still would drop to 400-500rpms.
after, i went home shut off the car then started it back up after a couple a mins.
this is all i did and the thing worked itself out.
it idles normally at 800ish and when i blip the gas its fine.
this might not b the same, but i thought id share.
