Newbie: stroker question
Old 07-16-2002 | 09:49 PM
Meccadeth's Avatar
Post Newbie: stroker question
What exactly is a stroker engine and how much HP gain does it achieve w/ different sizes (383, etc...)??
Old 07-16-2002 | 09:59 PM
Highlander's Avatar
Post
A stroker is a block used with a bigger stroke than originally designed... Or so...
its like the 350, 383, 396, 409, are strokers of the 327 or 302.
For instance the 350 uses a 3.48" stroke in the case of the lt1 and a 383 uses a 3.75", a 396 uses 3.85" and a 409 uses 4".
In the case for the ls1 the stroke is 3.62" for the 350 and 3.905" bore with a 4.00" stroke for the 383"
Keep in mind that the more stroke the more piston speed and the slower it will rev but more torque it will have at lower rpms
94B4C M6
Finishing project
Borla Competition--
AFR Heads
383 + Paxton Supercharger
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
Newgmman
02-25-2015 02:53 PM
D1SC383LT4
01-26-2015 01:41 PM
squirrels
07-13-2002 01:58 AM
Quick Reply: Newbie: stroker question
