NHRA Driveshaft loop specs????
Has anyone got a current NHRA rule book that tells where the driveshaft loop has to be placed on our F-body cars? We know what the material size required is: 2" x 1/4" steel stock, but do they say how far back from the front U-joint they can be or have to be, etc etc.??? We are putting my SFCs on, and were going to put a loop on it while we have it up in the air. If anyone has this info, and can post it verbatum out of the rule book I would sure appreciate it.
Thanks in advance. . .
Originally posted by MRZ28HO
6" back from the center line of the front U-Joint. Basically where the OEM "driveshaft loop" was, that sheet metal thing. Use the four bolts to mount it on.
Thanks for the info George. We have it installed now along with my new SFCs Going out to the local test & tune tonight and see how the new SFCs feel. Also installed a K&N FIPK on it. I will be ready now for this coming November when I enter an NHRA sanctioned event.
Appeciate your reply. . .
tdigger9899
09-07-2015 10:56 AM
