NOS system vs. Supercharger
Old 09-04-2002 | 06:49 PM
Z28sTunner's Avatar
Question NOS system vs. Supercharger
Admittedly, I am fairly novice when it comes to performance car tuning. I was weighing the pros and cons of installing either a NOS system or a supercharger on my car. WHich system is more reliable and can last with high performance results
2002 Z28 Navy BLue MettaLLic
  • A4
  • 160 degree Hypertech Thermostat
  • Granatelli MAF
  • Granatelli Cold Air Lid
  • K&N Filter
  • SLP Ram Air Kit
  • Hypertech Power Programming III
  • FLowmaster 40series Muffler
  • Borla Polished Tips
  • 30% sport tints, Plasma Bulbs
Old 09-04-2002 | 07:42 PM
96SFLZ's Avatar
Post
Well, the stock CR is 10.1:1 so IMO running anymore than 6psi of boost is asking for it. Even with only 6psi, you're still taking a chance. Nitrous works better with high compression so I personally think a 75-125 shot would be a better choice than boost. Of course, if you don't mind spending a little more $$ on a rebuild then I'd definitely go with the blower.
Aaron
Black '96 Z28 *sold*
¼- 12.97@107.2
SSM '02 Z28
Pro 5.0, FRA, MTI lid
¼- 13.21@108.2
Old 09-04-2002 | 07:45 PM
smallwood's Avatar
Post
Nitrous is alot cheaper for the same amount of power, but a charger is always there when you want that good feeling you get when you punch it, with no bottles to refill.
Little red light on the highway; big green light on the speedway, hey,hey, hey!
2002 Formula, GMMG cat back /1983 Z28-sold
Old 09-04-2002 | 08:05 PM
Drew778/94Z's Avatar
Wink
I'd go Nitrous, cheaper and safer.
2002 SS #3442 Navy blue metallic A4 160 T-stat/TB by-pass/SLP fan swich/DMS SFC's/Direct-Flo Lid/Holley Filter/FTRA/LS-6 MAF/Magna Flow Cat-Back/SLP Y-pipe/
(Very first run stock with 750 miles)
60ft 2.162 1/8 8.782@83.48 1/4 13.553@102.93
Best for now:
60ft 1.847 1/8 8.329 @ 84.72 1/4 13.014 @ 105.13
Old 09-04-2002 | 11:42 PM
nikkev's Avatar
Exclamation
I'd go nitrous.The only time you'll use it is the track.We already have too many ponies for the street as it is
Kevin
1998 Black Z28 A4
-------1/8-------
8.548 @ 83.64 MPH
Pics
Camaro/Firebird Birthday Bash
Old 09-04-2002 | 11:48 PM
smallwood's Avatar
Post
NEVER to many ponies for the street!
The purple stuff will really make it go, at least once.
Old 09-05-2002 | 12:33 AM
Freak's Avatar
Post
given a chioce (money no object) I would go with a supercharger (actulay Id go turbo, but that wasnt one of your choices)
the reason is simple, its always there. and I dont mean only when you HAMMER the vertical pedal on the right, at speeds above where the boost starts (usualy around 2000 RPM for a centrifugal blower) you will have that added power. this is useful on the street. Passing on the highway for example, you would have a little added power. unlike nitrous which should only be used at WOT and above 3000 RPM (minimum on these cars IMO) if you dont follow these guidelines with Nitrous, then you could end up with a very expensive paperweight.
EDIT: oh, 2 other reasons.
You dont hve to fill it ever
unless you have a convertable, the only out of the way place ot put it is either the spare tire comparment or int he rear hatch wehre the t tops go. I refuse to leave my spare at home, and dont wnat to give up my t top storage space (otherwise I wouldnt have gotten t tops)
[This message has been edited by Freak (edited September 05, 2002).]
10-31-2016 11:09 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
sbusaidi90
N2O Tech
04-22-2015 06:51 AM
CARiD
01-27-2015 06:27 AM
Quick Reply: NOS system vs. Supercharger
