Oil Change coming up. Recommendations?
#16
when it comes to oil, Patman is the one to talk to. i have read many of his posts on ls1.com and he knows his stuff. i believe he does oil analysis for a living or something like that
what do you think of the fram filter? i read some other posts saying it was a pos, but that was after i installed it
#17
Stay away from Fram! It's built with terrible internals, such as cardboard for endcaps! I like the K&Ns, Bosch Premium and for a low cost filter I like the Supertech from Walmart (which is made by the same guys who make the Bosch, K&N and Mobil 1 filters) The Mobil 1 filters are good but I believe they are a tad restrictive for hard driving. Champion Labs (who makes them) even says that their Mobil 1 filters are designed for high efficiency while the K&Ns are better for "sporting applications"
I don't do oil analysis for a living (I'm in the publishing business) I just do a lot of oil analysis testing of my own with the 4 cars in my family, plus I read a lot of oil analysis reports on the www.bobistheoilguy.com message board, where I am one of the admins.
I'm about to embark on a long term oil test where I won't drain my oil until the analysis says it needs to be done. I will sample it every 3k to test it. I expect to go over 10k in both cars. My wife's Honda will be running 5w30 Royal Purple for the test while my Formula will be running Schaeffer Supreme 10w30 blend.
#18
#20
Thanks man, I went out today and bought the stuff to change my oil, and was kind of in a hurry and the nearest autozone is like 20 - 30 mins away, so I went to the local auto store, and they didn't have the K&N in stock in my size, so I ended up getting a pureone cause that was the only other one other than purolator and the delco, is the pureone a good filter?
#23
Originally posted by StylezZ28
lol speaking of oil.,.. my g/f is on 17k late on her oil change... hmmm maybe her car will blow up soon.. lol.
#25
The PureONE is a good filter in terms of efficiency but I personally think it is too restrictive for a high performance application.
#26
Because the AC Delco only stops particles in the 25-30 micron range it will more than likely outflow the PureONE. Although without actual data on it's flow ratings it's hard to say for sure.
I do know that a PureONE filter is only good for a flow of about 3-5GPM while the K&N filters are in the 12-16GPM range! Finding out these flow specs for other filters is very hard though, most oil filter makers don't give out this data unfortunately.
#27
#29
Thanks for all the help man!!!! I never new the filter was that important! I've been using either the delco or the pureone the entire time i've had the car. I'll definately change that starting next time!!!!!
