Poll: Supercharging/Turbo charging and LS1....Good Idea?
Anyone know or heard anything about super/turbo charging an LS1. Would doing this reduce the life of the motor?
Is it a job that can be done by a do-it-your-selfer or does it need to be professional installed.
I believe that if they provide the power that they claim, an LS1 with a super/turbo charger would smoke just about everything on the road. I mean your talking about adding 100-150 hp with one bolt on. (I know they're expensive!)
Tell me what you guys think. Thanks.
1998 Z28. Artic White.
- SS hood
- Sport Appearance pkg.
- Ported, Polished MAFH
- Free ram air Mod.
- Flowmaster Exhaust
- Custom Stainless tips
- T-tops
- Fully loaded
I just got doen having a Procharger professionally installed. I love it!
I picked up a 900 miles used kit with all of the extras including new gauges for $3300 shipped(the basic kit goes for $5400). If I would have had the extra $3000 to throw around, I would have gone with a brand new Incon Stage II TT someone was selling. But a turbo setup is a bigger PITA to install, and requires a lot more tuning.
Cheaper and easier to do: Supercharger
More expensive but a lot more power: Turbo
1998 BG Chameleon Firebird Formula A4 - 2.73s, lid, filter, cutout
314 rwhp, 327 rwtq / 13.24@106.45, full weight and a 2.05 60'
President & Webmaster, Central Ohio F-Body Association: www.cofba.org
I personally do not recommend running much boost at all on LS1's or LT1's without internal engine work. The LS1's ringlands don't hold up well under extreme cylinder pressure. This is only my personal experience, and that's been with one Vortech car, and one Procharged car.
IMO, you're better off doing heads/cam for now, at least until you pull your motor out and put some lower compression pistons in with wider ring end gaps
White 1990 LX Hatch 5.0 Vortech S trim, other goodies
Black 1995 Honda Civic Ex Daily driver, 36 mpg
bigredjim.corral.net: now, banner free!
Ok, with the additional power, that pushes the car to 450 hp. That is not rally that much.
Deo\pending what you think is alot of hp. If you can do it, so can anyone else (the one power addrer theory).
Run up to most any Supra in Texas and you'll get smoked with only 450 h.p. Those cars for example can do that with only slight mods like turbo boost kit, and a computer upgrade.
I'd say change the cam and heads first then add the blower for 550+ h.p.
Check this site...221 HP 'bolt-on'
http://www.ls1motorsports.com/Single_Turbo.htm
1986 Buick Regal T-Type TE44, .030" TRW's, 43 lb injectors, ATR Downpipe, wastegate, ram air and exhaust, Lubrant chips, custom converter by Alan, Hot-wired 340 fuel pump, Bilstein shocks, GNX wheels, Ultralite gauges, and the whole METCO catalog
New Better Faster Engine Under Construction
1987 Buick Regal Turbo T 'Old Gray' GM Hi-Tech Performance magazine's project car - Ron Joseph bullet, Stage 5 60-1 turbo, DeQuick VR4 intercooler, Level 10 trans and converter, staged double pumper fuel system, 55 lb injectors, Bilstein shocks, Ultralite gauges, and the whole METCO catalog
2002 Camaro SS Sebring Silver hardtop with ebony leather, Hurst shifter, SLP lid, bellows, and ATS adapter, PS filter, CAGS!, BMR chrome-moly STB, METCO LCA's and bolt-in driveshaft loop
<font face="Verdana, Arial" size="2">
I'd say change the cam and heads first then add the blower for 550+ h.p.[/B]</font>
........hhhmmmm...well lets see..most of the Supras in town are around 550hp with the exception of "The Walser Supra"(874rwhp) and SW(I dunno the hp)but he ran 9.'s@150+traps....and Brice in houston (880+rwhp) and thats with 30k in mods...most of them are in the 11's so beating up on them with an F-body should not be to hard............I still hate those cars....
94 Z28 m6
cold air,air foil,b&m ripper,vortech tb elbow,underdrive pulley ,flowbasterd muffler,moded maf,poly trans mount,fuel pres reg,exhaust cut out........new mods 355/with 12# of procharger boost
99 Camaro SS m6
#133
MTI air lid,some free mods,B&M Ripper,MacEwen Motorsports WFG with no high beam thingy....slp longtubes w/o cats,zo6 maf,z06 clutch,jet pcm,qt cut out
Big Red(truck)
406 ci,700r4 w/3000 rpm stall,3.73 10 bolt.
No more 406..kaboom / on the way 427 mighty mouse
SpeedJunkee
06-06-2015 04:27 PM
