Problems - o2's, cats, worse?
I am showing the following codes:
P0161 - o2s Heater Circuit, Bank2 - Sensor 2, malfunction
P0420 - catalyst system, bank1, efficiency below
P1416 - Air system, bank2
What could cause all these codes to come up at the same time?
Re: Problems - o2's, cats, worse?
Originally Posted by SpeedDemon02SS
O2 sensors? all 4?
also, what do i do when i want to run headers with no cats? how do i make it so i wont throw a code every 5 minutes?
As for the problem solving...clear the codes and switch the rear O2's to see if the problem follows the sensor. At first glance, the one code would tell me the B2S2 sensor is bad. The other would suggest your driver's side cat is starting to go. But, I'd try a little troubleshooting before I threw parts at it.
**EDIT FYI**
B1S2/B2S2 part #25312197
B1S1 part #25312197
B2S1 part #25312196
Alex Barnes
01-24-2015 10:21 PM
12-01-2014 08:08 AM
slothgrant
08-22-2002 03:01 PM
