question about suspension or rear end
Old 09-26-2002 | 09:56 AM
1sloLS1's Avatar
my 98 just recently started doing this when i am under hard brakeing or accelerating right when the body first move ie the front end comes up or down i hear a light pop from the rear somewhere i have checked all the bolt on the suspension and they are all tight. secondly when i launch off the line the rear end fells like it hits the floor and moves but once again i checked the torque arm it is tight i also checked out the inside of my diff when i changed the fluid no broken teeth everything is good. i was thinkin mayeb the u joints cuase sometimes when i am driving at slow speed ie u turns if i come around the corner when the tranny is still in first and i get off the pedal right before it trys to shift into second you can hear a loud metal to metal thud under the car. sorry this is so long but i cant figure it out.
Old 09-26-2002 | 10:02 AM
BURNOUT5.7's Avatar
TRANS MOUNT. IF THE NOISE HAPPENS WHEN UNDER HARD ACCELERATION OR WHEN IT SHIFTS
Old 09-26-2002 | 12:14 PM
1sloLS1's Avatar
just at first instance when the body moves it seems to do it when the rear suspension flexes cause i have heard it do it in turns also.
Old 09-26-2002 | 12:16 PM
BURNOUT5.7's Avatar
examine rear springs for breaks
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
jcamaro95lt1
01-24-2015 08:21 AM
Collector Car
01-05-2015 10:58 AM
nodnarb481
Middle Atlantic
01-01-2015 11:43 PM
Quick Reply: question about suspension or rear end
