skip shift
you going with the skip shift kit thingie mabob or are you just getting a .20 cent resistor from radio shack? i would suggest the resistor.....cheap as hell, does the same thing.
if you use the resistor, you'll need:
*OH MY GOSH* -- the resistor
electrical tape
scissors -- to trim the wire extensions on the resistor
and of course a way to get underneath your car.
ls1.com has pretty well-laid out instructions to complete the process with pictures and all. i just printed out the page and glanced at them when necessary while installing the resistor.
*let the car cool a while if you had just been driving it before install, no need rubbing arms with the hot tranny....
**i further suggest to adaquately wrap the whole mess with tape so as to protect it from the elements....no need for water to splash all up in that crap....anywho....that's all i got.....took about half an hour from when the car went up in the air to when it came back down....
electrical tape
Re: skip shift
Originally posted by badassbowtie400
how hard is it to install the skip shift
http://www.installuniversity.com/ins...r/cags_slp.htm
I still see no use in this mod.. Personally, its lame.. The light still turns on.. Only now you can go into 2nd.. WOOHOO! Big whoop! Give it a little more gas, and VIOLA! YOU ARE IN 2nd!
wow!
JMO though.. have fun!
wow!
I just did mine a couple minutes ago. I went to Radio Shack and bought the 2.2k ohm 1/2 watt resistor, plugged it in, taped it up, zip tied the wire and that's it. It's done. Very easy.
psychocabbage, I thought the same for a while, but when taking a corner on snow/ice covered streets and having it do the 1st-4th thing all the time b/c you can't rev that high in 1st around the corner, it gets very annoying. Simple mod, and you get to choose your gear no matter what. Worth it in my book.
Its real easy man. I actually put mine in today. Jack up the car, locate the plug on the tranny above and toward the right/back of the orange sticker, disconnect and install the skip shift. Easy as that. Good luck with it and enjoy!
Originally posted by 2002 NBM Bird
Pretty sure its just a plug, should take no more than 15 minutes
what is the purpose of the skip shift
The bean counters were able to prove that by using skip shift, our cars would get better gas milage, thus eliminating the gas guzzler tax and keeping the price of the car down.
WobblySausage
10-07-2015 10:09 AM
