SLP airlid problem
SLP airlid problem
Just put a airlid on my 02 Z and when I drive normal its fine but when I floor it the passenger side clip pops loose on the front. Any quick fixes anyone knows or anything? Oh yes I have the smooth bellow on it as well if that makes a difference.
Re: SLP airlid problem
take the waste of money...i mean the bellows...off and put the stock piece back on.
the bellows doesn't allow enough flex between the engine and the lid.
or you could spend another $50 and put poly motor mounts to keep the engine movement to a bare minimum.
Don't ditch the bellow, you already bought and paid for it so it would be dumb to get rid of it. I had the same problem and found that the bellow wasnt all the way on the bottom of the MAF. Hope it's this easy for you.
Actually, the problem sounds like you don't have the lid lined up right. Most people make the mistake thinking the front part of the lid goes outside of the lower air box. But, it really tucks inside. Keep the bellow. Go back out to your car, loosen the metal straps and push the lid towards the motor. The front edge egde of the lid should tuck in just in front of the filter. Clamp the two front clips down and tighten up the metal straps.
you guy's were right i didn't have it pushed back far enough, as for the bellow i paid $50 for the lid and bellow off a wreck and they look brand new. and i figure power is power and every little bit helps. thanks for the help
F'n1996Z28SS
08-23-2023 11:19 PM
racecarz28
03-30-2015 09:55 PM
