Speedometer, Tac, Odometer, and radio stopped working
Old 01-04-2006 | 06:36 PM
Plague's Avatar
Ok, now this was weird. I am driving home and at a stop light the radio goes out for a split second. I look down at the dash and every light on the dash just turned on like the car was started. They turned off just like the car was started. My lights were on (head lights not effected by the event) and I was stopped. So I go down the road a few miles and this time the radio turns off, antenna goes down, tac goes to zero, odometer lights are out, speedo goes down to 10 mph. Car runs fine. I drove it several miles home after the incident. Car turned off fine. I started it up a few seconds later. No lights on the dash, so the same thing is going on. Anyone else had this?
thanks
Old 01-04-2006 | 07:05 PM
Plague's Avatar
Re: Speedometer, Tac, Odometer, and radio stopped working
I am not sure which bulb you mean. When I have my lights on all my lights seem to work, I can see the lights on the radio buttons, ac controls, and lights behind the dash that light up the speedo and tac. But, the needles for the speedo and tac do not work. The lights for the odometer do not work and the radio will not turn on. So, not sure what broke.
Old 01-11-2006 | 09:33 PM
00Z28SS's Avatar
Bad fuse I think. Check it on the side panel of the dash. It'll tell you what fuse it is, but I think the same fuse controls all the things you listed that went out.
phoenix95
01-08-2015 02:44 PM
phoenix95
01-08-2015 09:14 AM
Rod Bender
01-03-2015 03:15 PM
ANDYZ28
12-29-2014 09:13 PM
tweetybirdy
09-10-2002 02:36 PM
Quick Reply: Speedometer, Tac, Odometer, and radio stopped working
