sqeaky spring perches
Old 11-16-2003 | 02:01 AM
dregsz's Avatar
Hi All,
I have all the regular poly bushed mods on my '99 Z28 w 40k miles, Eibach pros, bilstiens, hotchkiss LCAa, BMR PHB.
The rear susp makes a squeak every time I go over a bump.
It doesn't do it when parked and I push on the bumpers.
I greased all the zerks and no difference.
The dealer said it could be the spring perches but couldn't find anything.
Anyone heard of this?
Just buy new perches from GM or what did you do to fix it, wipe em down w bearing grease?
Evan
Old 11-16-2003 | 01:50 PM
psychocabbage's Avatar
I have the same issue right now!
Just that I dont have any of the suspension mods and my car only has 29K miles.
Old 11-16-2003 | 08:59 PM
joSShua's Avatar
I also have been experiencing an annoying squeek when I hit light bumps in the road, not all the time though. If I get out right away and push up and down on the car, it goes away, temporarily. ? I have about 38k miles on my car. What the heck could it be????
Old 11-19-2003 | 03:07 PM
joSShua's Avatar
Does anyone have a clue? Much Thanks-
Old 11-19-2003 | 03:42 PM
coletrickle350's Avatar
I have the same problem fellas. I've greased and re greased everything and to no avail its still there. I've learned to live with it though.
Good Luck Mike
Old 11-20-2003 | 12:50 PM
PGR's Avatar
PGR
Rear sway bar bushings are notorious for drying out and squeeking.
Old 11-23-2003 | 02:53 PM
Mike_InMT's Avatar
Similar problem here - seems to be in the rear sail panel but it could be a suspension component. I'll check the rear sway bar when it gets back above 0 again.
95z28man7
N2O Tech
08-16-2015 10:58 AM
9t4lt4z28
Parts Wanted
07-19-2015 06:16 PM
Z28amustangklr
07-18-2015 11:05 AM
Catmaigne
07-14-2015 05:17 PM
Quick Reply: sqeaky spring perches
