Squealing + Coolant Issues
Old 10-29-2007 | 01:50 PM
Need4Camaro's Avatar
I'm hearing a squealing sound that perfectly matches the RPMS around the Belt area. I've just started noticing this sound after I changed my Water Pump... I'm hoping it's just a bad belt as the current one was only a Valuecraft and has been on there since November 2005. But last time it was my belt, I clearly remember the squealing STOPPING after the car warmed up. In my current case though it always squeals regardless of how warm or cold the car is and the faster I go, the louder it is... I'm going to replace the belts anyway since it's old, but how can I tell if it's a belt or a pulley? Sounds loudest near the Power Steering Pump.
As for the coolant issues, I replaced my water pump recently with a NEW one from Advanced Auto... I can't find any leaks since I've replaced my water pump yet everytime I come home and check my antifreeze, the radiator is only half full and the engine bay reeks of antifreeze. I can't tell if it's because of spilled antifreeze from the times I filled it previously or when I changed my water pump itself or if it's really leaking. I felt under the Thermostat too and it's completely dry so I doubt it's the thermo. No cracks in the hoses. Any ideas? I'm hoping it was just negligence and maybe the system wasn't completely full because I seriously don't want to have to replace that Water Pump again...
Old 10-29-2007 | 02:45 PM
Marc 85Z28's Avatar
Spray some WD40 on the belt with the engine running. If the noise goes away, and slowly returns, replace the belts.
Old 10-29-2007 | 03:55 PM
It went away for 5 seconds then came back... Belts?
Old 10-29-2007 | 07:28 PM
Marc 85Z28's Avatar
Yup, replace both belts.
Old 10-30-2007 | 12:47 PM
LastBreedLS1's Avatar
i replaced my belts after dealing with this same issue, the sound might come back. if it does its your under drive pulley.
Old 10-30-2007 | 02:44 PM
BadgeZ28's Avatar
I had a idler/tensioner bearing go bad. The noise increased and decreased with RPM.
Old 11-02-2007 | 02:24 AM
E-Dub's Avatar
How Much WOuld It Cost To Replace The Belts...Because I Just Noticed I Have THE SAME Problem...And ALso If It Doesnt Stop How Much Would It BE To Replace The Under Drive Pulley
calaban
05-18-2020 06:43 PM
kallcium
V6 Tech
10-07-2015 03:39 PM
warmeck
04-16-2015 05:53 PM
warmeck
03-22-2015 06:43 PM
MattFick
02-15-2015 10:16 PM
Quick Reply: Squealing + Coolant Issues
