SS Camaros & SLP Options
#16
Originally posted by Black01_Z
All SSs come with special floormats, keyfobs, and Camaro SS decals.
You get a different hood, spoiler, and 17 inch wheels instead of 16. A different airbox that opens on top to make use of the hood. You get a slightly different exhaust too (that doesnt mean the exhuast is better though)
The suspension is also slightly tweaked and has a bigger swaybar I think.
The above listed are all standard.
SLP options include an SLP motorsport Lid and SLP performance tuned exhuast system. IMO these options are a horrible waste of money. They cost alot more than they would on the aftermarket and you can find much better aftermarket replacements anyway.
Sucks though, I have the only SS I've ever seen without a "Camaro SS" dash plaque!
#17
Originally posted by Gossco95
So the hood scoop is functional?????? I must of not looked very well on the under side of the hood.
If you open up your hood and look at the underside of it, you can see the tunnels I'm talking about ... that's where the air's flowing.
Supposedly the LS1's way of doing it results in slightly better gains because air to the engine is more useful when it's not "turbulent." So channeling it through the hood smooths it out (like smooth bellows ... same idea).
#19
Its got the dual-tipped/dual SLP exhaust on it right now.... should I upgrade it? If so.... what would be the best..... i would like to hear it more inside the car.... but not sooo loud it overpowers the stereo system...
#20
get borla....i had the loudmouth but it got anoyying with headers....i have the borla and run it wide open....the borla comes with plates that u can switch out and make it quieter or louder....but when i hit the gas it screams....ask stik00 about it he likes it too
#21
-Mike
#22
Whats not debatable however is the fact that the aftermarket, whether you go with a open element system like hte K&N, a new lid, or one of the "ram air" systems will all be a good upgrade over the stock system regardless of whether you have a SS or not.
#25
Originally posted by HOSS99
If the SS has any Y2Y options, which are the SLP options, the options will be listed on a sticker inside the door.
#26
My SS came as a base model and does not have the internal badgeing as well. Most of the SLP stuff came as options. So if you ordered your car through a dealer and you knew all the option code you could get all the stuff. I found that most dealers did not know anything about the Camaro . no wonder they did not sell many of them
The SS hood does not act as a Ram Air system. I do not know where this comes from. If you look in the literature SLP even calls it a cold air induction system. On the Firebird it is a Ram Air system.
F'n1996Z28SS
08-23-2023 11:19 PM
Chrisdude
07-24-2002 02:25 PM
