SS and Z28 cpu's, THE SAME??
Old 05-05-2003 | 09:41 PM
Coop's Avatar
Question SS and Z28 cpu's, THE SAME??
OK, I am thinking about swaping out my M6 for a A4. Going to put in a built 4L60e. I was just going to swap out the cpus. Now, do I need to find an auto SS or can I use a Z28 instead? Let a brother know!
thanks in advance!
Old 05-05-2003 | 09:51 PM
JimMueller's Avatar
I would think so long as they have similar options from the same model year that it wouldn't matter. They'd both need to have the same rearend ratio, etc. Technically, the VIN will be wrong in the PCM. If someone reflashed the SS PCM back to the stock program for the M6 during troubleshooting, it might cause a hassle.
$0.02
Old 05-06-2003 | 07:00 AM
PhantomTA's Avatar
Moderator
just have your coputer flashed with an a4 program.. its that simple..
ive seen to many people try to swap computer only to have bad things happen
Old 05-06-2003 | 08:48 AM
CPFarhood's Avatar
Yes they are the same, but dave is right just have it flashed to an a4 program.
Old 05-06-2003 | 01:27 PM
Coop's Avatar
what could I use to flash the PCM to A4? Can you do that with a tech II? I have a couple of friends that work at a GM dealership so I could get my hands on one. Also, I heard you need the wiring harness to goto the 4L60e, where does the other end plug into? Are there just unused plugs sitting somewhere coming from the PCM?
sorry I guess they're stupid questions, but I don't know, hehe!
THANKS!
Old 05-06-2003 | 09:55 PM
rncotton's Avatar
You can do it mail order through Ed Wright or Thunder Racing
F'n1996Z28SS
08-23-2023 11:19 PM
Renegade Toker
01-23-2015 10:27 PM
NewsBot
01-11-2015 06:10 PM
01-05-2015 07:14 PM
cmdeshon
01-04-2015 11:15 AM
Quick Reply: SS and Z28 cpu's, THE SAME??
