stall????
Old 08-16-2002 | 03:40 AM
nautilus's Avatar
Question stall????
quick qustion...
when i look at torque converters, i see they are seperated by stalls, 2800, 3200, 3600...
i was just wondering what do these stall numbers mean and what is stall??
sorry for the ingorant question.
Old 08-16-2002 | 06:56 AM
96fbirdA4's Avatar
Thumbs up
Stall speed is the rpm where the converter begins to engage, moving the vehicle forward. On a stock A4, you can hold the brake with your left food and hit the gas with your right foot to bring the RPM's up to about 1600rpm or so before you will overpower the brakes and move forward.
- Steve - 1998 Pontiac Firebird Trans Am
LS1 A4, 2.73's, Kumho Ecsta Supra 712 245/50/ZR16's, Direct Flow Lid, GMAF, !FRA, Loudmouth, 3" Y-Pipe, AIT Mod, Fan Switch Mod
13.774 @ 103.33, 300.5rwhp & 308.6rwtq, 97+ RPO Codes, Join The CamaroZ28.Com Users Webring
Old 08-16-2002 | 10:40 AM
Camaro ChriSS's Avatar
Post
Try looking on the Yank Converter web site - Mike does a fairly detailed explanation. Having a higher stall converter essentially allows you to take advantage of the more torque and hp available at higher rpms by not engaging the engine until it is at a higher rpm.
Old 08-16-2002 | 10:45 AM
TA2001's Avatar
Post
here is some info about stall
http://www.ls1info.com/article.php?sid=253
Nayr
03-03-2023 08:34 PM
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
greenzee28
09-25-2015 04:29 PM
SEOJustin
09-24-2015 04:39 PM
damnyankee36
09-09-2015 07:06 PM
Quick Reply: stall????
