Steering arm hitting longtube.
Old 04-22-2003 | 07:44 PM
badeSSt's Avatar
hey guys i just finished installin flp longtubes today, damn it was a task. anyhow when i crank my wheel the bolt on the steering shaft hits the header and kinda gets stuck. what can i do to fix this? thanks in advance.
Old 04-22-2003 | 09:34 PM
Dr.Mudge's Avatar
Shave that bolt down with a grinder or cutting wheel, but leave enough so that you can grab it to remove in the future. Your not the only one with this issue.
Old 04-22-2003 | 09:40 PM
badeSSt's Avatar
thanks man, should i grind the head and the bottom threads?
Old 04-23-2003 | 12:49 AM
Dr.Mudge's Avatar
Grinding the threads wont make it go in further, you'll have to grind the head - how bad is the interferance?
Old 04-23-2003 | 06:28 PM
badeSSt's Avatar
well it hits enough to make the wheel stick which is kinda scary.lol
Victor Lamb
08-26-2017 02:52 PM
dbrockma
02-16-2015 02:56 PM
Quick Reply: Steering arm hitting longtube.
