Stock Dyno Run
Stock Dyno Run
Well got back from my stock dyno numbers and I cant stop smiling . I went with a bunch of guys from the Northwest LS1 forum. I pulled 322.8 RWHP and 333.4 RWTQ BONE STOCK . If i had a way to digitize the papers I would post the Graph.
Awesome numbers bro! Grats!
Southpaw,
98-00 came with ls1 intake. 01 & 02 models came with ls6 intake and will dyno about 10 HP more from it. Plus M6 cars dyno a little higher then A4's. And then you can have what they call "factory freaks" that dyno beyond the normal range for that year and trans like dis3as3d. On the other side of the fence you can get a facory "dog" that dynos less then normal.
Generally the 98-00 dyno between between 280-300 so this was definately a factory freak.
01 & 02 models are usually 305-320 stock with the M6's usually 10 horses or so higher then A4's.
Southpaw,
