Stock LS1 M6 1/4 mi times
Old 09-03-2004 | 08:47 PM
  #46
robb4964's Avatar
Re: Stock LS1 M6 1/4 mi times
Originally Posted by Capn Pete
Exactly! The rev limiter is truly set @ 6200 RPM (the Hypertech can raise or lower it from 6200) but due to the lag in the tach, then when you actually SEE 6200, it's too late, because the motor is ACTUALLY revving higher than that (and thus, the rev limiter is kicking in). Fine, with an automatic the stock shift points are set at about ~5800 RPM, but if I shift the car manually (before adjusting with the Hypertech) then I could hold the shifts out beyond 6000 RPM.
And for any dis-believers that a stock LS1 can't do a 12.xxx, maybe I haven't actually seen it either, but I don't doubt it. Look at my 1/4 mile times (with 2.73's or now 4.10's).....the times w/2.73's were on crappy tires, vs. with the 4.10's now, I've got tires that hook really well. SO, the power is getting put to the ground. If my car were an M6, which uses less engine power, then I'd probably be able to get my car to hit a 12.xxx AS LONG AS I COULD SHIFT!
Pete...call a Tuner and ask them what the stock parameters are on a LS1 in an F-bod..its not 6200 . Your car will not run that high RPM's stock . Wont do it ! I have seen the stock parameters Myself more then once . IM not going to argue from this point . Find out yourself .
Old 09-06-2004 | 11:44 PM
  #47
AL SS590 M6's Avatar
Moderator
Originally Posted by robb4964
F-Bods Do not go to 6200 RPM stock...Period......I know this for a fact . If your car says " 6200 RPM's" when you wind it up to that , either 1: it has some kind of tuning 2: The RPM gauge is wrong . Find a GM tech site and find out for your self . Thats one reason why people buy hypertech . The stock setting is like 5800 or 5900 Bye default . Just the facts man .
You sir are wrong. All LS1 F-bodys have a 6190 rpm redline. Actual rev limit. LT1 cars won't rev that high but LS1s do. This is a common known fact and has been so for many years.
Your source of info is erronious.
Old 09-07-2004 | 02:25 AM
  #48
Capn Pete's Avatar
Thanks Al. I was glad to hear some confirmation......I didn't think I was going nuts!?
Old 09-07-2004 | 10:09 AM
  #49
MY91Y84's Avatar
my dads 01 STRIPPER M6 ran a 12.89@109 completly FACTORY including PAPER filter...and stock ****ty tires..
hed hold the rpms at 2,800 and dumped the clutch featherd into it for a half seconds then went to the mat...powershifted 2nd and 3rd..bouned the rev limiter crossing the line...
1.97 60 foot...i ran it later in the day and went 13.06@108.8.
Old 09-07-2004 | 03:09 PM
  #50
97bowtie's Avatar
Wrong. LT1s are limited to ~ 5850 from the factory and LS1s 6200. Believe what you want.
Old 09-09-2004 | 10:41 AM
  #51
SVW99TA's Avatar
Well , I can tell ya I have never pulled a 2.0 sixty so yeah...your pulling pretty good sixties. But somethings not right . Could be the clutch . Youd be amazed at how much time you can lose with a crapy clutch. The HP will just slip away .
You are correct!! The clutch has gotta go. The nitto drag radials were hooking up like a dream, and the best 60' I got all night was a 2.06! I ran better last year with my street tires!! The clutch is junk!! My best run of the night was in the high 13.60's! You can feel it giving way on the launch and everytime you hit the next gear really hard! I am going to sell the nitto's now to start the fund for clutch replacement
Old 09-09-2004 | 04:02 PM
  #52
blacknight's Avatar
The two times I was on the dyno my car was revved to 6k rpm so the rev limiter must be 6200. The car made great power all the way up to 6k.
Old 09-28-2004 | 10:05 AM
  #53
Rifleman_btx's Avatar
13.74@104.42 that was at 35 PSI all the way around. (02 Z28 6 speed) This Friday I'm going to drop the rear pres. to 25 PSI and see if I can get any better.
Old 09-28-2004 | 10:31 AM
  #54
BirchMan98z's Avatar
I managed a 13.08 @ 106 on a 90+ degree day, and did a burnout on street tires. I didn't know any better at the time, and it was fun. Car was bone stock, crappy factory tires, paper filter, and a lot of gas in the tank. Not bad for my first time at the track. I got it down from a 13.42, to a 13.23, 13.10, and finally my 13.08. I'm positive I could have hit 12's in my stock 98, but we'll never know.
Old 09-28-2004 | 10:32 AM
  #55
I'd say 18-20psi if you want them to grab a little better. Some people say go lower, but then you risk spinning the tire off the wheel-- and at high speeds, that's bad.
Old 09-28-2004 | 01:32 PM
  #56
Yeah, thats why I was feeling like playing it safe going with 25, but I'll give that a try 20-22 after that if I don't feel the improvement. I just don't feel right going below 20.. Like you say bad things could happen.
Old 04-10-2005 | 01:48 PM
  #57
2nd2none's Avatar
I ran a 14.2 on my stock 94 Z28 M6, I hope to run my 02 M6 Trans AM this week.
Old 04-12-2005 | 11:55 PM
  #58
robb4964's Avatar
That's crazy, considering mine went 14.008 @ 101 (2.1 60') w/A4 + 2.73's when it was stock (might have had the lid then? ). The only problem was it was very hot and VERY humid when I ran it back then. But still, considering I've got 4.10's now, and I'm still not into the 12's yet!? (and poor traction isn't a concern whatsoever now).
There is a guy here who ran a 13.2 in a stock 00 Formula and with lid and free mods ran a 12.8@108. With nothing more then a few bolt on's on a cold azzz night he ran a 12.6. Stock gears/cam/headers. I seen it.
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
jayblev95
Track Kill Stories
01-15-2015 07:48 AM
Quick Reply: Stock LS1 M6 1/4 mi times
