Stupid question.. ADJ Rocker Arms and 7.4 PR's??
Would paying a little extra eliminate the search for correct PR length? Just a theory question..
And yes I know the PR Length Chcker is like $20.. but still.. .I'll be doing my cam with in a month, and I was thinking of just getting 7.4 PR's and ADJ rockers..
Sorry if this may be a stupid question.
Stock rockers. I used them on all of my setups. The only real upgrade is shaft, but I doubt you want to spend $1000 on rockers and it's not usually necessary on a hydraulic roller car spinning less than 7200 rpm.
I'm using stock rockers with 7.4s
That's true. Also, most cams use a few "shelf" masters unless the cam grinder has to use a CNC machine to cut it if it's a completely custom cam.
