Sub-frame connector for 02 Convertible?
Hey all,
Just recently purchased an 02 Z28 Convertible, and as I was perusing the internet looking for some quick upgrades, I came across the sub-frame connectors. Since I drive a convertible, I figured adding rigidity to the chassis would be a great upgrade, but all of the connectors I saw said they would not fit on a convertible.
This makes sense, since I know they have to bolster the frame since the roof isn't there to help, but I was wondering if:
A. Anyone makes a sub-frame connector for a convertible (or, if adding one in would help at all)
B. If anyone could post some pictures of the underside of a hardtop (or T-top) so I could do a comparison. (Sadly, googling didn't turn up much)
Thanks for the help!
Re: Sub-frame connector for 02 Convertible?
The big difference on the convertible is the addition of a large sheet metal "X" that (***I think***) ties the subframes to the trans mount and the cross-brace under the driveshaft tunnel. I've also seen reports that the rocker panels have additional sheet metal reinforcements added. I would suspect the problem is the x-brace and the sheet metal may interfere with the traditional SFC's, which hug the rocker panels.
Currently, SLP (which has pretty much abandoned the 4th Gen F-Bodies) only lists SFC's for "coupes"..... no convertibles.
Camaro/Firebird Suspension (1982-2002) - Category Results - slponline.com
carguyshu
01-22-2017 11:19 AM
NewsBot
06-22-2015 10:30 AM
NewsBot
06-22-2015 09:10 AM
Richardan15
05-30-2015 08:36 AM
