Surge Tank Replacement on C5
I did a search and couldn't locate this topic so I'm making a post.
The coolant surge tank on my C5 is a bit leaky. Can this be repaired or should I just go ahead and buy a new tank? I looked into it and it looks like it's only three bolts to replace it and I could probably do it myself, but wondered if a fix was possible to get me by. It's leaking along the seam. The local shop wants $200+ to replace.
Your input is appreciated!
Or you can get it here for $21.99 + shipping...
http://www.corvetterecycling.com/pro...301189-816.htm
It's 3 10mm nuts and some hose clamps. 5 minutes of work TOPS.
Magenta_Hearts
03-22-2015 03:36 PM
Magenta_Hearts
03-05-2015 07:01 AM
