Towing with and Fbody?
Old 11-18-2002 | 07:39 PM
BlackVelvet's Avatar
I am going to be moving from MI to CA in the next month. I was planning on pulling a small trailer behind my 98Z. What is a good hitch that is very hidden looking? Is there anything special I should knwo about towing with a Z?
Thanks you guys are always great with replies
Old 11-18-2002 | 08:14 PM
V6toZ28's Avatar
Rent a truck and tow the Z.
MRZ28HO's Avatar
Thumbs up
Although I have never done such, you might want to ask the help of two people over at the SSOA board. Ask/look for Teri or Steve Heino. They have towed a small trailer (looks like parts of an SS car) behind their SS.
Old 11-20-2002 | 01:29 AM
PGR's Avatar
PGR
The Z28 is a decent tow vehicle, with its low CG and live axle. I use mine to tow a motorcyle trailer, with a couple of dirt bikes. I've towed from northern CA down into to Baja Mexico - no problems.
I have a Eyers Class 2 (3500 lbs) hitch on my '94 6-spd. It is very sturdy, however the left exhaust tip needed to be bent down to clear the hitch. The frame rails at the rear of the car are not centered (the right side rail is shifted over to make room for the spare tire). So the hitch clears the right exhaust tip, but not the left.
Go down to your local hitch shops, and have them show you their set-ups, and make sure they fit the car properly before you buy.
68camaroboltz
10-05-2015 01:46 PM
dkred94z
08-20-2015 03:09 PM
Thirim
07-30-2015 01:29 PM
Boss002
07-24-2015 10:47 AM
meissen
06-01-2015 07:59 AM
Quick Reply: Towing with and Fbody?
