Transgo Question
Transgo Question
the 98-02 z28's have 4l60e's right? and is the Transgo shift kit for that electronic? are you able to turn it off and on??
99 Z28RS
SLP LoudMouth
SLP Air Temp Module
MTI Carbon Fiber Air Lid/K&N
EGR Mod,FRA Mod
99 Z28RS
SLP LoudMouth
SLP Air Temp Module
EGR Mod,FRA Mod
99Z28RS,
You are correct, the transmission is a 4L60E. The Transgo shift kit is permanent. The kit replaces parts within the transmission/valve body and cannot be turned off.
B&M sells an electronic shift improver. Hypertech programers offer the option.
The Transgo will provide quicker and firmer shifts. By my understanding, the electronic controllers simply increase line pressure to firm a shift, but do not actually quicken it.
Michael
Bright Red 1997 Z-28 A4
MODS: Suncoast SS hood, GM SS ram-air box c/ Holley Powershot filter, MTI airfoil, ZR-1 17X9" rims, 275/40R17 Dunlop 5000s, SLP 2-on-da-left catback, Hypertech 160 thermostat, Hypertech Power Programer III, 1LE induction elbow, Taylor 8mm SpiroPro plug wires, Energy Suspension torque arm bushing, 1LE boxed lower control arms, BMR relocation brackets, Trans Go "Shift Improver" kit
STEREO: Pionner 7000R CD headunit, Fultron "Memphis Belle" amp, 1 pair Memphis 6.5 coaxles, Cerwin Vega Stealth 6.75 componets, 2 Orion XTR DVCs subwoofers.
TIMES: 60'=2.063 1/8th=8.964@80.21 1000'=11.434@91.44
Michael
GA93FORMULA
07-24-2002 11:38 PM
Camaro90RS
07-23-2002 07:57 AM
