true dual over the axle pics
Old 11-22-2003 | 04:10 PM
FLIPPINZ28's Avatar
does anybody have any pics of true duals on a ls1 or lt1 over the axle out the rear i really need some pics to show my exhaust guy and also should i connect the two pipes with an H pipe. what will it do if i dont add a h pipe please help thanks
Old 11-22-2003 | 04:36 PM
Capn Pete's Avatar
H-pipes or X-pipes (X-pipes being the best) are not a MUST, but I think most guys would highly recommend them. Their purpose is to balance out the exhaust pulses or something like that, and in essence each bank helps draw the exhaust out from the other one. If you don't use an H or X-pipe, you won't notice anything wrong, and it won't make the car run bad, but it's just better to use one.
Old 11-22-2003 | 06:20 PM
FLIPPINZ28's Avatar
why is it better to run one if it doesnt change anything? any pics thanks for your help capn pete
Old 11-22-2003 | 06:21 PM
FLIPPINZ28's Avatar
by the way you have nice cars
Old 11-23-2003 | 01:47 AM
99BlackZ28T56's Avatar
I was looking into this for awhile. The only way to go over the axle that I found was to use 2 2.5" pipes next to eachother in the stock location. 3" won't fit and there's not room on the drivers side from what I read. Most just dump before the axle. Another option to an x-pipe is use a magnaflow dual/dual muffler with a straight through x design. Part #11379 and 11386 aluminized, #14379 and 14386 stainless. 3" mufflers avaiable too. Kill 2 birds with one stone for $100. Never heard this setup but I may try it.
Old 11-23-2003 | 01:53 AM
FLIPPINZ28's Avatar
see i also have to worry about emissions so i must exit to the side or the rear i cant dump before the axle. i wish i could though any pics
Old 11-23-2003 | 12:03 PM
teke184's Avatar
www.ls1speed.com has one in their "exhaust" section of the ls1 camaros
Old 11-23-2003 | 01:34 PM
FLIPPINZ28's Avatar
that picture works great thanks i will show him that. any more closeups
Old 11-23-2003 | 02:24 PM
Camaro_Guru16NY's Avatar
It was my understanding that an X pipe was need.. Especially on the Ls1 s due to the fireing order and Gas pulses. NOT saying im right but this is what Ive heard. Ithink It would be a worthwhile adventure but I would say just dump it before the Rear Axle. Its the cheapest way to do and still sound damn good..
Good Luck,
-JOHn
Old 11-23-2003 | 03:23 PM
96SFLZ's Avatar
Here's one running both over the axle on the passenger side (stock location): http://www.cardomain.com/member_page...273735&page=10
Here's another, running a very, VERY tight (not tight as in "cool") setup: https://www.camaroz28.com/~chris/mmexhaust/
The T/A (1st one) is owned by a member here: thegrasshopper24. I'd PM him with any questions you might have.
Camaro_Guru16NY, he can't dump them before the axle (because of emissions).
Old 11-23-2003 | 05:47 PM
FLIPPINZ28's Avatar
thanks everybody for the pics and help i am going to do a 2 1/2 twins out with some mufflers dont know which yet what would yall recommend not drag loud. also an H-pipe thanks
QuickSilver02
04-07-2015 11:12 AM
alphaauto
01-22-2015 08:02 PM
Queens94z28
11-20-2014 06:03 PM
guionM
9
08-29-2002 01:48 PM
Quick Reply: true dual over the axle pics
