Trunk Latch Problems?
Old 01-15-2003 | 11:40 PM
v10power's Avatar
I know about the problems with the trunks on these cars not popping open, and I am going to put a helper spring on ti combat this annoying problem. My question isn't regarding that, When I pop the trunk and open it the latch seems to reclose as if I have shut the trunk lid. SO I have to release the trunk latch with the remote and when I hear it activate I have to actually open the latch with my finger. Has anyone had this problem? THe stealership said that they couldn't find anyhting wrong. It doesn't do it everytime, I'd say it does it once every 5 times. Do I need to replace the whole latch assembly? Any ideas? Thanks guys
Old 01-16-2003 | 04:03 AM
stik6shift98's Avatar
i havnt heard about that....
mine works fine and 5 other fbods around here have no probs either
Old 01-16-2003 | 11:39 AM
XKnightRider's Avatar
If the spring mod doesn't work you most likely need a new assembly. The spring mod worked for me, but for others it had to be replaced.
Old 01-16-2003 | 03:52 PM
fbird95's Avatar
try the spring mod, or of you have a waranty just get the dealership to give you a new one. It may be a challenge to show them the problem if its not consistant.
redleader
Parts Wanted
11-13-2016 02:57 PM
CARiD
02-09-2015 09:35 AM
squarehead
11-21-2014 08:02 PM
Doug Harden
11
07-14-2002 04:31 PM
Quick Reply: Trunk Latch Problems?
