Tune?
Old 08-24-2007 | 09:55 PM
CVsFinest's Avatar
Question Tune?
I just installed my Kooks race headers, Kooks ORY, and a magnaflow catback. I also deleted my EGR and AIR. The car runs great but I know LT make the car run rich. My question is how long can i go for with out a tune???????? Can I damage anything while going WOT?? thnks Eddie
Old 08-24-2007 | 11:44 PM
SSpdDmon's Avatar
Misconception. LT's make the car lean out. Actually, any mod that helps the engine breath easier will lean it out. The fuel trims try to make up for it and richen the AFR back up some. But, I have seen cases where cars are actually lean at WOT.
A good tuner will help clear up some of the AFR issues, get you ~10hp (typical gains), and kill any codes/adjust fans/adjust shift pressures/etc.
Old 08-25-2007 | 06:28 AM
AL SS590 M6's Avatar
Moderator
Do you have any kind of a scan tool available to use?? If so drive the car 10-15 miles varing between 50-60 and using 3rd and 4th gear. If the long term fuel trims stay less than 15-20 then you could drive it without hurting it. If the LTFTs max out (25) then it must be tuned.
Now with that said. Your best bet is, as stated above, get it tuned and get the codes turned off. The car will run noticably better.
Old 08-25-2007 | 09:58 AM
CVsFinest's Avatar
nah i dont have a scan tool, i guese i just have to take it easy till i can get a tune
Old 08-25-2007 | 11:58 PM
Me>you's Avatar
yeah, make sure you take it real easy...It'll blow up if you don't...lol
Get a tune, it'll help a great deal with a tune...Better yet, buy a cam right now and install it as soon as you get it, then get a tune...
Old 08-26-2007 | 09:41 PM
CVsFinest's Avatar
im going to do a h/c combo hopefuly next spring or summer i will do a full custom tune then. do i really have much to worry about now tho?? in about a month i will get a street tune. I was just wondering if I ould beat on it till then
08-24-2015 06:41 AM
sherwinZ28
11
08-15-2015 05:38 PM
RallyRed701/2
07-27-2015 02:55 PM
colts0455
07-24-2015 04:51 PM
Shookiez28
07-23-2015 01:55 PM
Quick Reply: Tune?
