turn signal
turn signal
help an idiot out here, I cant figure how to get my passenger side turn signal bulb out to change it, took the plastic peice under the car and still can not get at the bulb with my fat hands...
There's a little latch that holds the bulb fitament in place. Pull the tab out from it's latch and then unscrew the bulb counter clockwise. It comes out easy once you find it. I've had to replace the bulbs several times due to water getting in both my turn signal housings. I hope this helps.
stangspank
11-13-2015 01:02 PM
Darth Xed
13
07-22-2002 12:45 PM
CMJ917-95CMO
06-19-2002 09:10 PM
