Vacuum Lines to Vacuum Solenoid
Old 12-11-2008 | 12:18 AM
CIVY's Avatar
Had my Intake manifold off and now I'm not sure if I have the vacuum lines to the vacuum solenoid plugged right. There are two ports on the vacuum solenoid........one runs to the back of the intake manifold and the other runs to the air shut-off valve. Can someone take a look under their hood and tell me if the short vacuum line that goes to the top of the air shut-off valve goes on the top or bottom port on the vacuum solenoid. It would be much appreciated!!!
2002 LS1 Z28
Old 12-11-2008 | 08:10 AM
Kraest's Avatar
Retired
Some pics of LS1 engines with instructions on simple repairs/installations on LS1howto.com. I'd go look at my car, but it's snowing outside
Old 12-11-2008 | 10:05 AM
CIVY's Avatar
I checked that web site and scoured the web but have not found a single picture that clearly shows the vacuum lines on the vacuum solenoid. It would difficult to get one in any case because of the location.
HectorM52
07-30-2017 11:46 AM
Nellsw88
05-26-2015 05:55 AM
Patrick Kovack
03-08-2015 09:26 AM
grgguy
17
02-23-2015 07:57 PM
blac94Z
11-28-2014 01:53 PM
Quick Reply: Vacuum Lines to Vacuum Solenoid
