Valve sizing
Old 02-12-2006 | 12:52 AM
UltraZLS1's Avatar
Valve sizing
Ill be getting some patriot 5.7 perimeter bolt heads in the near future.
I was wondering which valve size would be best in my car.
2.02/1.57 or 2.055/1.60
pro's and cons of each? power differences?
Im on stock cubes/224 cam/full bolt on/m6
thanks a lot
Old 02-12-2006 | 09:08 AM
Greed4Speed's Avatar
Re: Valve sizing
Are you going to run a larger cam?
If not stick with the smaller valves.
Cons of larger valves is shrouding. Bigger is not always better
Old 02-12-2006 | 10:08 AM
UltraZLS1's Avatar
Re: Valve sizing
Come to find out they will mill them or make them any cc chamber I would like for free.
So....Should I have them changed?
What cc? Any milling?
It is a daily driver, I just want the most streetable power I can get out of these heads.
Ill be using stock head gaskets
Old 02-12-2006 | 10:41 AM
YBNORMEL's Avatar
Re: Valve sizing
I have 2.02 valves in A.S. heads. The one advantage was that I went from a 224 cam to a Futral F13 without having to worring about cleareance that might have been an issue with a 2.05 valve.
The car made good power with the small valves.
Old 02-12-2006 | 11:19 AM
Re: Valve sizing
If you want smaller chambers, just get LS6 or 5.3L heads. Why mess with valvetrain geometry when you can get heads cast with smaller chambers and retain factory geometry?
Might want to check out the PRC heads Texas Speed is selling CHEAP.
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
QuickSilver02
04-07-2015 11:12 AM
drptop70ss
03-26-2015 01:50 AM
Timberwolf
10-10-2002 05:25 PM
Quick Reply: Valve sizing
