went to the track clucth pedal fell to the floor need help
Old 09-30-2002 | 09:49 AM
coolguy's Avatar
I took MY 98 z-28 6-speed to the track on friday for the first time but on all the 3 runs when i was doing my burn out the clucth pedal would fall to the floor. I wasnt riding it at all i was doing the side ways foot pedal move you now the way you have to do a burn out on a stick car, and the pedal would fall to the floor, you clould smell the clucth really bad, i have 40,000 miles on the clucth, alot of people told me it was my slave cynlinder. what should i do, should i just replace the slave or both the clucth and slave? what kind of clucth should i get? how are those Z06 clucths? thanks for all the help
Old 09-30-2002 | 10:05 AM
psychocabbage's Avatar
HMMM.. Why were you doing a burnout? Were you using drag radials or street tires?
If I were going to replace my clutch, I would use Spec.. I have yet to hear anything bad about them.
Not sure about your problem, but I personally would not of kept on it if I smelled any clutch burning.
Old 09-30-2002 | 11:23 AM
coolguy's Avatar
well i wasnt ridfing the clucth but somebody told me it was my hydrolics, also what kind of spec clucth should i use, all help would be great, thanks
Old 09-30-2002 | 11:55 AM
1sloLS1's Avatar
a buddy of mine put a spec stage 2 clutch in his 93 and that is the sweetest clutch i have driven i literally cant stall the car if i had a stick again i would get one.
Old 09-30-2002 | 03:15 PM
I ususally see posts where people are using these..
Stage 3 - Stage 3 clutches come with a sprung center disk with pads. The pads are available with a Kevlar disk or carbon disk, which will hold 680 horsepower, or or a ceramic disk, which will hold 700 horsepower.
You get to choose Kevlar, Carbon, or Ceramic..
http://www.thunderracing.com/index.c...ategoryid=1081
has them
Old 09-30-2002 | 03:18 PM
BlackHawk T/A's Avatar
Are you on stock or street tires? If so your burnout was completely pointless and will only make your traction problems worse. You only want to turn them over a few times to clean them off, smoke is bad.
z28cam1993
06-23-2015 09:14 PM
CARiD
04-08-2015 08:08 AM
cyteone
02-07-2015 06:04 PM
Red97LT1
9
12-17-2014 06:13 PM
simple
08-11-2002 11:56 AM
Quick Reply: went to the track clucth pedal fell to the floor need help
