What is an LS1 Bumpstop mod?
Old 07-26-2002 | 05:26 AM
BIGRED Z's Avatar
Post What is an LS1 Bumpstop mod?
What is it? What does it do? Thanks.
Lori <--------not a mechanic
Lori
My Z
35TH ANNIVERSARY Z28 ported throttle body*ported MAF sensor* cold air induction *throttle body bypass*3" cutout*LS1 bumpstop mod*K&N filter
Old 07-26-2002 | 06:15 AM
ratio411's Avatar
Post
Hi Lori,
Here you go:
http://www.installuniversity.com/ins..._bump_stop.htm
Old 07-26-2002 | 11:04 AM
Camaro ChriSS's Avatar
Post
When I did my car, the TB was only opening to 81.8 degrees (not the more ideal close-to-90). The blade was only opening up 93% of the amount it should under WOT.
It doesn't hardly make a difference to performance, but every little step helps.
13qtr
10-28-2016 08:11 PM
1slow93z28
09-01-2015 06:22 PM
Nickster 7
08-27-2015 10:12 PM
Jocofire1
08-07-2015 03:16 PM
CARiD
07-07-2015 08:19 AM
Quick Reply: What is an LS1 Bumpstop mod?
